manutro
Jan 12, 2017Aspirant
RND2000 v1 Lost permissions after damaged disk
Hi, I have a Readynas duo V1 with firmaware 4.1.14 and 2 disks of 2TB in RAID 1. May SO is Windows server 2012 R2. When a hard disk is damaged NAS is not accessible until I remove the damaged disk....
- Jan 12, 2017
Hello manutro,
Can you try resetting permissions? Get to FrontView then Shares > Share Listing and click one of the shares that you have are trouble with then click Advanced Options. Make sure Share folder owner and Share folder group fields are set to root then Share folder owner rights, group rights and everyone rights are set to Read/write. Mark both "Set ownership and permission for existing...." and "Grant rename and delete priviledges... ", click Apply button. Then test again to see if you get the same results.
Welcome to the community!
FramerV
Jan 15, 2017NETGEAR Employee Retired
Hi manutro,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Dec 28, 2018Retired_Member
