manutro
Jan 12, 2017Aspirant
RND2000 v1 Lost permissions after damaged disk
Hi, I have a Readynas duo V1 with firmaware 4.1.14 and 2 disks of 2TB in RAID 1. May SO is Windows server 2012 R2. When a hard disk is damaged NAS is not accessible until I remove the damaged disk....
- Jan 12, 2017
Hello manutro,
Can you try resetting permissions? Get to FrontView then Shares > Share Listing and click one of the shares that you have are trouble with then click Advanced Options. Make sure Share folder owner and Share folder group fields are set to root then Share folder owner rights, group rights and everyone rights are set to Read/write. Mark both "Set ownership and permission for existing...." and "Grant rename and delete priviledges... ", click Apply button. Then test again to see if you get the same results.
Welcome to the community!
manutro
Jan 16, 2017Aspirant
Hi,
All my backups are Ok!
Reseting permissions worked for me.
Thanks for your help again.
- Dec 28, 2018Retired_Member
