CChewie
Mar 14, 2017Aspirant
RND2000v2 (ReadyNAS Duo v2) stuck on 'system starting up' RAIDar
Hi All, I'm hoping someone can help me please. I'm pretty stuck and not sure what else to try. I have a ReadyNAS Duo v2 which has been working fine for a number of years. It has 2x3TB HDDs ins...
CChewie
Thanks StephenB. Your suggestion is much appreciated!
I will try this and let you know how I get on.
Thanks!
CChewie
Hi StephenB.
Apologies. I'm not sure what i am doing with R-Linux. I think i have the see the correct partition.
But when i click Open Drive Files, it says the below:
I'm wondering if I am missing a step(s) here or something. Could you possibly provide me with a few high level steps or tips in using R-Linux for windows please?
Thanks in advance! Kind regards.
- StephenBMar 14, 2017Guru - Experienced User
Were you using XRAID on the duo v2?
I think you are actually doing it correctly. Try the other drive.
