CChewie
Mar 14, 2017Aspirant
RND2000v2 (ReadyNAS Duo v2) stuck on 'system starting up' RAIDar
Hi All, I'm hoping someone can help me please. I'm pretty stuck and not sure what else to try. I have a ReadyNAS Duo v2 which has been working fine for a number of years. It has 2x3TB HDDs ins...
CChewie
Yes. I think it is XRAID. I assume it is like a traditional RAID1 Mirror but Netgear's own proprietary one.
Do I need to initiate a scan, on R-Linux, on the partition?
I will try the other drive tomorrow.
Thanks!
Thanks!
CChewie
Mar 15, 2017Aspirant
The 2nd drive is behaving in a simar way. So I have reinstalled the 1st drive back into the USB HDD caddy and have initiated a 'detailed' scan on the largest partition.
Fingers crossed it will find a file system with files which i can restore.
- mdgm-ntgrMar 15, 2017NETGEAR Employee Retired
Have you checked the disk health using SeaTools?
- CChewieMar 27, 2017Aspirant
Sorry. I forgot to update this thread. Been extremely busy and losing hope in recovering this data.
I ran the scan function on R-Linux for over a day and it didn't find any data. I try the quick option to see if its any better.
I also tried SeaTools but ithe tool doesn't start up properly. It hangs on scanning for USB Devices. I wonder if it fails/hangs cause there is an issue with the HDD.
Thanks,
Chris
