Flyfish_2002
Jan 20, 2018Aspirant
RND2110-100NAS installation problems
Hi. I purchased the above unit off of eBay about 12 months ago. I plugged it in when I received it, it powered up then I put it on a shelf This week I purchased two WD20EARS-00S8B1 2TB HDDs to ...
- Jan 22, 2018
Thank you. Installed the two HDDs, Raidar found the new unit, currently updating firmware.
Appears I am in business.
Appreciate the help.
Jan 22, 2018Guru - Experienced User
The OS is installed onto the disks, so you can't do anything if the unit has no disks inserted.
Flyfish_2002
Jan 22, 2018Aspirant
- Flyfish_2002Jan 22, 2018Aspirant
Firmware updated, NAS found and accesible, volume is synching...takes awhile but making progress.
