rbush
Sep 22, 2016Aspirant
RND2110 v2 will not start up
Last week I stopped being able to access my ReadyNASRND2110v2 NAS on my network and the unit was powered down. I tried starting and the hard disk would spool up and stay spinning and I still had no ...
- Sep 28, 2016
Thanks for your advice - it gives me a lot to think about.
rbush
omicron_persei8
Sep 22, 2016Luminary
Is it a Duo v1 or a v2 ?
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Be careful with the label on the NAS, it's misleading.
Does RAIDar see it?
- rbushSep 23, 2016Aspirant
The label says: "ReadyNAS Duo RND2110 v2 Model RND2110-100NAS 1X1000SG XRAID". I don't use RAIDar as I only have 1 disk installed in it and saw no sense in installing the ap since the browser interface had all the functionality I needed.
When I enter the network address Windows says it is unavailable at this time. Again, the disk is spooling and doesn't settle down into its normal quiet spun-down standbuy mode.
- StephenBSep 23, 2016Guru - Experienced User
rbush wrote:
The label says: "ReadyNAS Duo RND2110 v2 Model RND2110-100NAS 1X1000SG XRAID"...
As the article says, that means you have a v1 (sparc-based unit). The -100NAS is the tell, a v2 would have a -200NAS. The v2 in the label doesn't mean what you think it does.
rbush wrote:
I don't use RAIDar...
RAIDar gives status information, and the NAS sometimes responds to it even when the web interface is down. So please install it, and tell us what it says.
- rbushSep 24, 2016Aspirant
Nada - now I have a useless piece of software on my computer that does nothing.
I tried taking out the hard disks and starting up the unit - same spinning sound, so evidently what I thought was the hard disks spooling up is something else inside the NAS. Still doesn't settle down into normal standby mode except that when I pressed the power button and held it to shut it down, it did shut down - I didn't have to unplug it like I do when the hard disks are in it.
