MK21
Sep 13, 2017Aspirant
RND2150-100NAS Power Light blinking
Heard a weird noise from my RND2150-100NAS, so tried rebooting it by holding the power button down. Since the device wouldn't reboot that way, just unplugged power and tried to do hard reboot, which...
Marty_M
Sep 20, 2017NETGEAR Employee Retired
Hello MK21,
It does appear that after generating a weird noise and power button stop responding you can no longer detect the NAS on the network. This might be signs of internal or hardware fault, please try to bypass the network connect computer directly to the NAS and check if the raidar can detect it. Also please check if you could still access and the boot menu of the NAS.
Welcome to the community!
Marty_M
NETGEAR Community Team
Sep 20, 2017Guru - Experienced User
Also I suggest checking out the two disks with seatools if you can - that requires access to a Windows PC and perhaps a USB->sata adapter.
