Preppie
Oct 25, 2021Aspirant
RND2150 Disk Tray Struck
I have an older NAS RND2150 (2009 vintage). I recently lost a disk and found out my disk tray is stuck. This is the older style disk tray where the release is an indented circular button. Both trays ...
- Oct 26, 2021
Thanks. The 2nd method worked like a charm. I had to shine a light on it to see the plastic peice that needed to move.
Oct 25, 2021Guru - Experienced User
There are two possible ways. One is to try inserting a bent paperclip into the hole in the center of the button.
If that fails, you can also insert a small screwdriver or bent paperclip into one of the "B" slot(s) as shown below. There is plastic piece behind those slots (marked in cyan in the picture) that you push towards the button to release the latch. FWIW, I've had better luck using the second method.
