starbase804
May 28, 2019Aspirant
RND4000 Odd issue
Readynas started playing up today. DNLA works and all my films are playing on the TV ok but cant connect to the drive via laptop or app and its showing as no RAID Tried doing an OS install but the ...
May 29, 2019Guru - Experienced User
Where? Can you post a screen shot?
starbase804 wrote:
or app?
Which app?
Are you running Windows 10? If not, what are you running?
What firmware is running on the NAS?
starbase804
May 30, 2019Aspirant
I added an attachment pic to my original post, did it not work?
running windows 10 but can access the files from an android tablet either like I am used to doing.
when i said app i was talking about my android file explorer app.
RAIDiator 4.1.15
- starbase804May 30, 2019Aspirant
meant to say that i CAN'T access from my adroid devices.
here are the details. front screen on the NAS reads the correct disk usage but web screen shows 0% usage. but the DLNA server is still serving all my media files.
Model: ReadyNAS NV+ [X-RAID]
Serial: 23J3017U0046A Firmware:
RAIDiator 4.1.15 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
IPv4 address:: 192.168.0.100
Volume C: Online, RAID Level , disks, 0% of 0 MB used
- StephenBMay 30, 2019Guru - Experienced User
Ok. So SMB/CIFS has stopped working and Frontview is thinking you have 8 MB disks with a 0 MB volume. DLNA still functions.
Something looks very wrong.
- Can you download the log zip file? (Don't post it here, but it'd be good to have it).
- Is SSH enabled on the NAS?
- Do you have a backup of the files?
- how do i get the log file?
- Is SSH enabled on the NAS? - No Idea.
- Do you have a backup of the files? - No.
when i tried to reinstall the os from usb i get the "os index error" and it hangs there
when i try to do anything from the web front end that requires a reboot it wont reboot itself.
