starbase804
May 28, 2019Aspirant
RND4000 Odd issue
Readynas started playing up today. DNLA works and all my films are playing on the TV ok but cant connect to the drive via laptop or app and its showing as no RAID Tried doing an OS install but the ...
starbase804
May 30, 2019Aspirant
I added an attachment pic to my original post, did it not work?
running windows 10 but can access the files from an android tablet either like I am used to doing.
when i said app i was talking about my android file explorer app.
RAIDiator 4.1.15
starbase804
meant to say that i CAN'T access from my adroid devices.
here are the details. front screen on the NAS reads the correct disk usage but web screen shows 0% usage. but the DLNA server is still serving all my media files.
Model: ReadyNAS NV+ [X-RAID]
Serial: 23J3017U0046A Firmware:
RAIDiator 4.1.15 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
IPv4 address:: 192.168.0.100
Volume C: Online, RAID Level , disks, 0% of 0 MB used
- StephenBMay 30, 2019Guru - Experienced User
Ok. So SMB/CIFS has stopped working and Frontview is thinking you have 8 MB disks with a 0 MB volume. DLNA still functions.
Something looks very wrong.
- Can you download the log zip file? (Don't post it here, but it'd be good to have it).
- Is SSH enabled on the NAS?
- Do you have a backup of the files?
- starbase804May 30, 2019Aspirant
- how do i get the log file?
- Is SSH enabled on the NAS? - No Idea.
- Do you have a backup of the files? - No.
when i tried to reinstall the os from usb i get the "os index error" and it hangs there
when i try to do anything from the web front end that requires a reboot it wont reboot itself.
Heres a portion of the visable log
Thu May 30 01:00:58 WEST 2019 Volume scan failed to run properly.
Thu May 30 00:51:53 WEST 2019 System powering off...
Tue May 28 23:30:24 WEST 2019 System is up.
Tue May 28 23:26:02 WEST 2019 Volume C is approaching capacity: 99% used 87G available
Tue May 28 23:24:40 WEST 2019 Volume scan failed to run properly.
Tue May 28 23:03:01 WEST 2019 System powering off...
Tue May 28 21:30:48 WEST 2019 RAID sync finished on volume C. The volume is now fully redundant.
Tue May 28 13:32:53 WEST 2019 System is up.
Tue May 28 13:26:20 WEST 2019 RAID sync started on volume C.
Tue May 28 13:23:07 WEST 2019 Volume is approaching capacity: 100% used 112k available
Tue May 28 12:53:46 WEST 2019 System is up.
