starbase804
May 28, 2019Aspirant
RND4000 Odd issue
Readynas started playing up today. DNLA works and all my films are playing on the TV ok but cant connect to the drive via laptop or app and its showing as no RAID Tried doing an OS install but the ...
May 30, 2019Guru - Experienced User
starbase804 wrote:
meant to say that i CAN'T access from my adroid devices.
here are the details. front screen on the NAS reads the correct disk usage but web screen shows 0% usage.
Ok. So SMB/CIFS has stopped working and Frontview is thinking you have 8 MB disks with a 0 MB volume. DLNA still functions.
Something looks very wrong.
- Can you download the log zip file? (Don't post it here, but it'd be good to have it).
- Is SSH enabled on the NAS?
- Do you have a backup of the files?
starbase804
May 30, 2019Aspirant
- how do i get the log file?
- Is SSH enabled on the NAS? - No Idea.
- Do you have a backup of the files? - No.
when i tried to reinstall the os from usb i get the "os index error" and it hangs there
when i try to do anything from the web front end that requires a reboot it wont reboot itself.
