har02052
Nov 25, 2014Aspirant
RND4410 V3 upgradeable?
My brother has an RND4410 V3 which currently has 4X1Tb drives in it. He no longer wants it. I am just wondering if I buy it off of him, can I upgrade the drives to something like 4x2, 4x3, or 4x4?
RX
Nov 25, 2014Luminary
You can only used up to 4x2TB drives for the ReadyNAS NV+ v1 that your brother has. You may check the compatible list of drives for your ReadyNAS NV+ v1 by following these steps below:
1. Access this link below:
http://kb.netgear.com/app/answers/detail/a_id/20641
2. Select Legacy on the drop-down menu that says "Select your device to display Hard Disk Compatibility list." Another drop-down menu will appear.
3. Select ReadyNAS NV+ v1 on the next drop-down menu that will appear. All of the compatible list of drives for ReadyNAS NV+ v1 will be displayed.
