Donkoe
Aug 16, 2022Aspirant
RNDP2000 will not stay on
My RNDP2000 will turn on, lights on network interface, but turns off after about 1.5 minutes.
I am unable to keep on long enough to troubleshoot.
Ideas?
I am unable to keep on long enough to troubleshoot.What firmware is it running?
Was the onset of this issue sudden, or did you sometimes have issues with it locking up before?
- SandsharkSensei
Can you grab the log file before it shuts down to see if it's shutting down under control (shutdown is logged) or you ju st see the next power-on without a prior shut-down?
If it's uncontrolled, then a power issue could be it, it could be bad RAM, or it could be a (probably erroneous) indication of over heating.
If it's controlled, hopefully the logs will be informative as to why.
If it's a power issue, a new power brick might help, but I wouldn't put a lot of hope in that.
- DonkoeAspirant
Thank you for your reply.
i am not able to get into it (might be a bad process on my part).I have it plugged into my network. I see the IP on my router, but I am unable to get to it via a BROWSER interface.
Is there some other preferred method.
As an aside, I was able to see the data on the drive via RECLAIM software, so I know the data/drive is good. It is just the devide. RAM is a good thought. It was VERY DUSTY inside. I cleaned it out, but it could still THINK there is a heat issue.If there is a good process for seeing logs, or consoling in, please advise.
Thank you again!
Don
- DonkoeAspirant
The onset was sudden.
I am unfamiliar with the device. I am 'tech support' for family members, and this is one of those instances.
