luukee's avatar
luukee
RNDP200U having network issues
hey guys   i'm having this issue with our NAS and not sure what's happening.   we have a Model: RNDP200U and it loses network connectivity (no pings) upon manual restart it would work again.  it'...
  • StephenB's avatar
    Jun 28, 2017
    luukee wrote:
    I coudn't find the OS partitian log, but i found the partition log.
    Look at the first device listed in disk_usage.log
    Filesystem Size Used Avail Use% Mounted on
    /dev/md0 4.0G 1.7G 2.2G 44% /
    tmpfs 16K 0 16K 0% /USB
    /dev/c/c 14T 8.7T 5.0T 64% /c
    Mine is rather full BTW, normally is is around 20%
    luukee wrote:
    Settings for eth1:
     Speed: 100Mb/s
    Is this expected?  Most people with x86 NAS are using gigabit networks.
    If you are connecting to a gigabit switch or router, then you probably have a bad cable.  You could shift it to the other ethernet port, and see if that also negotiates the same speed.
ProSupport for Business
