huuga
Oct 21, 2019Follower
Rndp4000 doensn't starting
Hey everyone, I've some troube with RDNP4000. After power surge it won't to start. LED panel lighting up for few seconds, and after that RNDP switching off. I guess something happen with power. How ...
Oct 22, 2019Guru - Experienced User
JohnCM_S wrote:
You can also use 3rd party data recovery software. Some members used Reclaime for data recovery. You may wait for other Community members for suggestions on what data recovery software you can use.
ReClaime will work, but it is expensive. If you are running 4.2.x firmware on the NAS (that is, you haven't converted it to run OS 6), then R-Studio is much less expensive and should do the job.
If you buy a replacement x86 ReadyNAS (RN300 or above) then you can also temporarily mount your array in the new NAS, offload the data, and then complete the setup. It will need to reformat the disks - so you would need restore the data from the backup when you are done.
Sandshark
Oct 24, 2019Sensei
If you have converted your Pro4 to OS6, then you can simply move the drives to a new OS6 NAS.
One other option is to configure a cable to temporarilly connect a standard ATX supply to your NAS. There is a pin swap-out that needs to occur, it's not just a standard 20-pin ATX connection, though it uses the same connector. Your Pro4 uses the same pin-out as for the NV in this diagram: ReadyNAS_PSU_pinout.pdf .
