rtryp's avatar
rtryp
Follower
Aug 02, 2024
RNDP6000 - Volume C - Offline
Hello- Currently running a ReadyNas Pro 6- RADiator 4.2.31
So I had 6 3tb drives running in the X-Raid array configured for dual-redundancy.  I had disk 3 fail. I didn't have another 3tb drive on hand so swapped in a brand new 4tb. (WD Red).  System detected drive and started a rebuild.  About 10 minutes in I get the error message:
Volume scan found errors that it could not easily correct. Please ensure that you have current backups of all valuable data before performing a full volume scan by rebooting the NAS through Frontview with the volume scan option enabled.
And my access to the data is gone.  Share list in frontview is still there but greyed out.
1.) I then rebooted with volume scan checked.
System reboots and reports same error as above and I still can't access date
2.) I pull the drive because the rebuild doesn't seem to be moving.  I put the old drive back in and it's still reported dead.  I reboot and same error. Can't access my data or shares.  Volume C on main screen of frontview reports as OFFLINE.
3.) I put the new 4tb drive back in and let the rebuild go overnight.
The next day the resync is complete.  All drives report healthy.
Volume C is still offline and I can't access my data or shares.  I attempt the reboot option 'skip volume check' via paperclip.  Same thing. Can't get to my data.
I think my data should still be intact as I only had one drive failure and was configured for dual redundancy.  Is there a way to force this volume C back online? I do have SSH enabled and can SSH into the box if needed.
Any tips would be greatly appreciated!
I'd try for a paid support call but seems they don't offer that anymore for this unit.
1 Reply
  • StephenB's avatar
    It might be too late to sort out what happened, but I still suggest downloading the full log zip, and looking in there.
    You could try RAID recovery software such as R-Studio:
    This runs on Windows, and would require a USB enclosure or enough docks to connect the disks to the PC.  You'd also need enough storage to offload the data.
ProSupport for Business
