tdaters's avatar
tdaters
rndp6000 won't boot or reset
just purchased a rndp6000 started fine, then after copying files it stopped and now won't boot and i can't even get to the reset menu display show readynas and fans run, but no hard drive activ...
  • Sandshark's avatar
    Sandshark
    Nov 19, 2018
    Did you test the voltages under load?  If not, the test is far from comprehensive.  While there are two 12V load segments, they tend to be tied together at some point (though I have not tested that with the ReadyNAS supply).  Your next best step is to try another supply.  Rather than buying one that will fit internally, you can use a standard ATX supply (that perhaps you "borrow" from a PC) and plug it in externally.  If that doesn't fix it, then it's something else.  Without schematics, which Nethgear has never made available, further troubleshooting is mostly shots in the dark.
ProSupport for Business
