nickel22222
Jan 01, 2019Tutor
Help troubleshooting rndp6000
I am troubleshooting some issues with new old (newly acquired) RNDP 6000 100NAS.
This board won't allow me to post my log in zip format.
Not sure if disk network or other problem. Trouble with writing to NAS from computer with Acronis true image 2019.
p.s. some of the higher temperature operation is when I had the A/C off of minute and should not be an issue.
Please advise.
nickel22222 wrote:
The wifi uses your Netgear DC112A-100NAS cradle with ATT wifi hotspot.
Uses "ac" I think.
It's not mine - I don't work for Netgear (neither does anyone else you've been connecting with here). This is a community forum, you are talking with other users.
It is an 802.11ac device (2x2 in the 5 ghz band), so you should be seeing better speeds if you are close to the cradle. Perhaps confirm that you are connecting to the 5Ghz band.
There is some privacy leakage if you post the full log zip file, so please don't do that.
It's fine to cut/paste a small section though.
Are you seeing any issues reading/writing to a NAS share? You can use Nastester to test this: http://www.808.dk/?code-csharp-nas-performance.
i typed in the ip address 192.168.100.21 and get errors.
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
An error occured: Could not find a part of the path '192.168.100.21\1test.tmp'.
Running a 400MB file write on 192.168.100.21 5 times...
Running a 400MB file read on 192.168.100.21 5 times...
An error occured: Could not find a part of the path 'C:\Users\AsuS\Downloads\NASTester_17\192.168.100.21\1test.tmp'.- StephenBGuru - Experienced User
You're entering the wrong thing. You need to specify a NAS share as the destination, and you need use the UNC format.
For instance, if you have a share called Media, enter \\192.168.100.21\Media in the network path field. Note the direction of the slashes - that matters.
