nickel22222
Jan 01, 2019Tutor
Help troubleshooting rndp6000
I am troubleshooting some issues with new old (newly acquired) RNDP 6000 100NAS.
This board won't allow me to post my log in zip format.
Not sure if disk network or other problem. Trouble...
- Jan 04, 2019
nickel22222 wrote:
The wifi uses your Netgear DC112A-100NAS cradle with ATT wifi hotspot.
Uses "ac" I think.
It's not mine - I don't work for Netgear (neither does anyone else you've been connecting with here). This is a community forum, you are talking with other users.
It is an 802.11ac device (2x2 in the 5 ghz band), so you should be seeing better speeds if you are close to the cradle. Perhaps confirm that you are connecting to the 5Ghz band.
nickel22222
Jan 01, 2019Tutor
i typed in the ip address 192.168.100.21 and get errors.
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
An error occured: Could not find a part of the path '192.168.100.21\1test.tmp'.
Running a 400MB file write on 192.168.100.21 5 times...
Running a 400MB file read on 192.168.100.21 5 times...
An error occured: Could not find a part of the path 'C:\Users\AsuS\Downloads\NASTester_17\192.168.100.21\1test.tmp'.
Jan 01, 2019Guru - Experienced User
You're entering the wrong thing. You need to specify a NAS share as the destination, and you need use the UNC format.
For instance, if you have a share called Media, enter \\192.168.100.21\Media in the network path field. Note the direction of the slashes - that matters.
