nickel22222
Jan 01, 2019Tutor
Help troubleshooting rndp6000
I am troubleshooting some issues with new old (newly acquired) RNDP 6000 100NAS.
This board won't allow me to post my log in zip format.
Not sure if disk network or other problem. Trouble...
- Jan 04, 2019
nickel22222 wrote:
The wifi uses your Netgear DC112A-100NAS cradle with ATT wifi hotspot.
Uses "ac" I think.
It's not mine - I don't work for Netgear (neither does anyone else you've been connecting with here). This is a community forum, you are talking with other users.
It is an 802.11ac device (2x2 in the 5 ghz band), so you should be seeing better speeds if you are close to the cradle. Perhaps confirm that you are connecting to the 5Ghz band.
Jan 01, 2019Guru - Experienced User
There is some privacy leakage if you post the full log zip file, so please don't do that.
It's fine to cut/paste a small section though.
nickel22222 wrote:
Not sure if disk network or other problem. Trouble with writing to NAS from computer with Acronis true image 2019.
Are you seeing any issues reading/writing to a NAS share? You can use Nastester to test this: http://www.808.dk/?code-csharp-nas-performance.
- nickel22222Jan 01, 2019Tutor
i typed in the ip address 192.168.100.21 and get errors.
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
An error occured: Could not find a part of the path '192.168.100.21\1test.tmp'.
Running a 400MB file write on 192.168.100.21 5 times...
Running a 400MB file read on 192.168.100.21 5 times...
An error occured: Could not find a part of the path 'C:\Users\AsuS\Downloads\NASTester_17\192.168.100.21\1test.tmp'.- StephenBJan 01, 2019Guru - Experienced User
You're entering the wrong thing. You need to specify a NAS share as the destination, and you need use the UNC format.
For instance, if you have a share called Media, enter \\192.168.100.21\Media in the network path field. Note the direction of the slashes - that matters.
- nickel22222Jan 02, 2019Tutor
Got it working.
Running warmup...
Running a 400MB file write on \\192.168.100.21\nas 5 times...
Iteration 1: 7.19 MB/sec
Iteration 2: 7.37 MB/sec
Iteration 3: 7.31 MB/sec
Iteration 4: 7.17 MB/sec
Iteration 5: 6.92 MB/sec
Average (W): 7.19 MB/sec
-----------------------------Looks ok.
What log files do I post to ensure mem and cpu and disks are
Jan 01, 2019 13:58:30 System: ReadyNASOS background service started. Jan 01, 2019 13:58:21 System: ReadyNASOS service or process was restarted. Jan 01, 2019 10:01:26 Volume: Disk test completed for volume NAS. ok?
It doesn't say if disk check was good or not. Just that it was completed.
- StephenBJan 02, 2019Guru - Experienced User
nickel22222 wrote:
Got it working.
Running warmup...
It looks incredibly slow. Over gigabit ethernet you should be seeing something close to 100 MB/sec. Is this over wifi?
Download the log zip file.
Look in disk_smart.log to see the details of the SMART stats.
Also you can see networks stats in network_settings.log
