tdaters
Nov 17, 2018Aspirant
rndp6000 won't boot or reset
just purchased a rndp6000
started fine, then after copying files it stopped and now won't boot
and i can't even get to the reset menu
display show readynas and fans run, but no hard drive activ...
- Nov 19, 2018
Did you test the voltages under load? If not, the test is far from comprehensive. While there are two 12V load segments, they tend to be tied together at some point (though I have not tested that with the ReadyNAS supply). Your next best step is to try another supply. Rather than buying one that will fit internally, you can use a standard ATX supply (that perhaps you "borrow" from a PC) and plug it in externally. If that doesn't fix it, then it's something else. Without schematics, which Nethgear has never made available, further troubleshooting is mostly shots in the dark.
tdaters
Nov 28, 2018Aspirant
it was the power supply after all.
have a new sfx ordered.
now trying to get readycould, but i have an old one that reports the mac address as the serial number.
i know there is a work around, do you have it?
thanks
tim
