NoKeRse
Oct 14, 2021Aspirant
RNDU 4000 x 2 with corrupt VPD
Hi, I have been a long time lurker of the Netgear forums. And have enjoyed a lot of good guides and tutorials both from NTGR employees and the community. During a autumn cleanup, I found my...
mdgm
Oct 14, 2021Virtuoso
Before jumping to conclusions, have you tried a different web browser?
Have you checked if you can connect to the NAS using SMB to view files?
- NoKeRseOct 14, 2021Aspirant
Hi,
Thanks for your reply!
Tried all of the browser I can think of. With various settings. Developer tools in Chrome states that the product number cannot be null. And all blank both on serialnumber and productnumber in Raidar 6.5
OS reinstall, factory reset etc has been tried to no avail.
The units has most likely been loaded with alternative OS, and when I started them a few days ago I was not able to do a factory reset nor accessing the boot menu, so in a last resort I went for a USB recovery. and after reading a little bit more I can see that may not have been my smartest move ;)
All drives are empty and trying to access the nas-ip/shares also just shows a blank page aswell.
Hoping for a reply from either NTGR or some of the other wizards on this community in what to do next. :)
- SandsharkOct 15, 2021Sensei
With that additional information, I agree that it appears the VPD file is corrupt or missing. Since it is encrypted, only Netgear can re-create one for you.
- NoKeRseOct 15, 2021Aspirant
Hi sandshark,
Yup should have included the information in my first post.
Since Im gonna upgrade them to ReadyNASOS 6 and not use ReadyCloud. Is there any way to do so from Tech Mode? By applying the update that way? for instance by using the following guide; https://dae.me/blog/1724/forcing-readynas-to-update-via-ssh-when-all-else-fails/
Any way of getting the Netgear Teams attention to the thread?
