kyoba1
Dec 01, 2012Aspirant
RNDU2000 - setup freeze with Seagate ST2000DM001
Hi, I try to install two Seagate ST2000DM001 (2To) in my RNDU2000. (1cH164-301 / FW : CC24) The disks are empty and in the compatibility list. The NAS was working well with another small disk befo...
HBNorm
Dec 08, 2012Aspirant
I'll add my own situation as it overlaps. I added the same Seagate Drive to replace a failing drive on my ReadyNas NV+ (V1). The drive resynced only to fail the next day. From there, that threw my whole NAS into failure mode. The new Seagate drive works fine on my laptop and desktop...also works fine if I reboot the NAS with only that drive plugged in as the OS will re-install and everything is fine. What's up ReadyNAS team? I will post a separate post for my specific issue. Just wanted to add my 2 cents here as it's the same drive that started my own nightmare.
