bpito
Jan 03, 2021Aspirant
rndu2000 : no volume
Hello, I have a rndu2000 to which I had a single 1TB hard drive. I wanted to add a second 1TB hard drive and since then nothing works. Through the administration interface I have "No volume e...
- Jan 05, 2021
Welcome to the Community!
If you want to use both 1TB drives you have to use Flex-RAID and use both drives as JBOD. If it is already setup, you will have to switch to Flex-RAID and then destroy the volume to create two JBOD.
HTH
Happy New Year!
rn_enthusiast
Jan 03, 2021Virtuoso
I can take a look at the logs for you, if you like.
Follow instructions here: https://kb.netgear.com/25625/How-do-I-send-ReadyNAS-system-logs-to-NETGEAR-Support#OS4
Upload the log-set to Google Drive, Dropbox or similar and PM me the link to download them. Don't post the logs publically here.
Then I can take a look and see what is going on. Cheers
