s96talle
Dec 02, 2017Aspirant
RNDU2000 has died?
Hi! My ReadyNAS has died, the power cord show the green light so it seems to put through power but something has happened on the way to the NAS. Is there anyway to switch the DC IN module? Is t...
Sandshark
Dec 03, 2017Sensei
Just because the LED is lit on the supply does not mean it is supplying sufficient voltage and power to the NAS, yo could determine if it maybe just needs a new supply. But to answer your question, no, there is no separate power module in the Ultra2, nor are parts available from Netgear. There are ways to use a PC to recover the files, Netgear can help you recover them with a newer model NAS, or you could get any of the legacy Intel based units to swap your drives into, as long as it is still running OS 4.2.x.
bedlam1
Dec 03, 2017Prodigy
The Ultra 2 has an external PSU doesn't it ?
These are widely available and relatively inexpensive, try googling "Netgear Ultra 2 Power Supply"
- s96talleDec 03, 2017AspirantThanks, tried with another PSU that works but NAS still dead. 😔
- StephenBDec 03, 2017Guru - Experienced User
If you can connect one of the disks to a Windows PC, you could try r-linux for windows ( http://www.r-tt.com/free_linux_recovery/ ). It should be able to read the NAS data and let you offload it.
