Felix_jn
Jun 23, 2021Aspirant
RNDU2000 REINSTALL OS
Recently,my nas has driver fail,so I reinsert two empty hdd,try to reinstall OS,but it stuck on Loading kernel modules... here is the tty output. CPU : Intel(R) Atom(TM) CPU D425 @ 1....
mdgm
Jun 23, 2021Virtuoso
Does it boot successfully into tech support mode (a boot menu option)?
The old BIOS wouldn't be related to this problem.
- Felix_jnJun 23, 2021Aspirant
Yes~ same stuck on Loading kernel modules...
- SandsharkJun 24, 2021Sensei
How are you observing that boot process? On units running OS4.2.x that have a VGA port, that's about all you see even when it boots properly. But I've never looked on an Ultra2.
- Felix_jnJun 24, 2021Aspirant
I can access nas from minicom,no need vga, the ttl output always stuck on Loading kernel modules.(normal boot, reset factory,reinstall os&tech support mode)
- Jul 15, 2018Retired_Member
