Felix_jn
Jun 23, 2021Aspirant
RNDU2000 REINSTALL OS
Recently,my nas has driver fail,so I reinsert two empty hdd,try to reinstall OS,but it stuck on Loading kernel modules... here is the tty output. CPU : Intel(R) Atom(TM) CPU D425 @ 1....
Felix_jn
Yes~ same stuck on Loading kernel modules...
Sandshark
Jun 24, 2021Sensei
How are you observing that boot process? On units running OS4.2.x that have a VGA port, that's about all you see even when it boots properly. But I've never looked on an Ultra2.
- Felix_jnJun 24, 2021Aspirant
I can access nas from minicom,no need vga, the ttl output always stuck on Loading kernel modules.(normal boot, reset factory,reinstall os&tech support mode)
- SandsharkJun 24, 2021Sensei
So you are using the serial port? Did you ever observe it before and know that it normally displays more than that? As I said, units with VGA don't with OS 4.2.x, but do with OS6. I rather expect the same is true on the serial port, but I've never looked at it.
yes ,I had tried install xynology on external usb driver before .so I observe the proper boot process,it only stuck a few seconds on this ,then network light will be on.
there is a vga port on motherboard,but i do not know the linear sequence, the serial port is enough,you can even access bios over serial port
- Jul 15, 2018Retired_Member
