maxsun
May 29, 2023Aspirant
RNDU2000 reset admin
Hi, We have forgotten the admin password to our NAS, i've tried to reset it using the os reinstall seen here: https://kb.netgear.com/21100/How-do-I-access-the-boot-menu-on-my-ReadyNAS-Ultra-2-Ul...
May 30, 2023Guru - Experienced User
maxsun wrote:It seems to reset the device (the ip changes) but i still can't log in with the default login admin/netgear1, any ideas?
what firmware are you running?
Are you getting to the username/password prompt?
- maxsunMay 30, 2023Aspirant
It's running OS 4, I do get the user/password prompt but the default password doesn't seem to work.
- StephenBMay 30, 2023Guru - Experienced User
Is RAIDar giving you any useful status (version 6.5 is ok for this)
Also, please confirm that you are browsing to https://nas-ip-address/admin (using the real IP address of course). You do need to explicitly enter the /admin suffix.
Do you have the add-on for TLS 1.2 support installed?
Thank you so much for your time; unfortunately, it doesn't seem to work even with the /admin suffix; I've tried all these logins: https://kb.netgear.com/1148/What-are-the-default-user-interface-passwords-for-NETGEAR-devices
Raider looks like "I gott skick" which means "in good condition."
I don't have any addon for tls 1.2, but I'm able to bypass the invalid certificate, so that shouldn't be the issue. I would greatly appreciate any ideas.
