pvdwaal
Sep 27, 2013Aspirant
RNDU4000 - No space left on device (28) - SOLVED :)
Hi, I've have the returning problem that NZBGet gives the error: Warning: session_start() [function.session-start]: open(/var/lib/php5/sess_e825e68ac41faac8d1c187538625e3f1, O_RDWR) failed: No ...
pvdwaal
StephenB wrote: I don't use NZBGet, but generally speaking if there is room on the C volume, then the error could be a result of the OS partition filling up.
L3 support can clean that up fairly quickly. Don't delay, as this condition can totally lock up the NAS.
After it is resolved, there is a ReadyDLNA add-on that will put the DLNA database on the C drive (instead of the OS partition) which can help.
Thanks for the reply, but I really would like to be able to fix the problem myself and better: find the source of the problem in order to prevent it for happining ever again.
L3 told me that it was fixed, but appaently not :(
Do you have the link to the add-on you mentioned? It should be something with DLNA. Here is the L3 quote:
> The DLNA cache had exhausted the inodes in the OS partition.
> I hope that newer version of miniDLNA will prevent this from happening
> again but would like to log in to check.
After login thay said everything was OK. That was on 2012-10-18 and now the problem is back
