pvdwaal
Sep 27, 2013Aspirant
RNDU4000 - No space left on device (28) - SOLVED :)
Hi, I've have the returning problem that NZBGet gives the error: Warning: session_start() [function.session-start]: open(/var/lib/php5/sess_e825e68ac41faac8d1c187538625e3f1, O_RDWR) failed: No ...
mdgm-ntgr
Oct 01, 2013NETGEAR Employee Retired
Correct. If you want to revert the change (not sure why you would want to do this as the inodes would likely get filled up again) you would install the add-on again. It's a toggle.
