pvdwaal
Sep 27, 2013Aspirant
RNDU4000 - No space left on device (28) - SOLVED :)
Hi, I've have the returning problem that NZBGet gives the error: Warning: session_start() [function.session-start]: open(/var/lib/php5/sess_e825e68ac41faac8d1c187538625e3f1, O_RDWR) failed: No ...
pvdwaal
Oct 01, 2013Aspirant
mdgm wrote: Correct. If you want to revert the change (not sure why you would want to do this as the inodes would likely get filled up again) you would install the add-on again. It's a toggle.
Thanks!
Appreciate all your help :)
