keeprg8
Nov 19, 2016Aspirant
RNDU4000 - OS Reinstall, fix frontview and various other problems
model: RNDU4000, firmware 4.2.28 Hi All, I recently had an: "ERR: Could not find internal fla" I fixed it with the "USB Restore flash" guide and it appeared to be working normally ... ...
- Nov 24, 2016
Okay ... Tried what I beleive is everything, found the (afaik) original .deb files from "/var/cache/apt/archives/" and executed "apt-get -i *.deb" in that directory, manually "apt-get install"'ed the oldest versions, took a chance, rebooted the nas - and presto - now everything works ...
So ... note to self .. dont "apt-get upgrade" blindlessly :o)
If you for some reason deleted the files from "/var/cache/apt/archives/" then "Factory Default" might be the only solution ...
Nov 21, 2016Guru - Experienced User
keeprg8 wrote:
My question is:
Will the OS Reinstall boot option, fix the frontview, php problem, and maybe transmission, without removing the users and their permissions on the nas, and most importantly my data...
It shouldn't remove users, change permissions, or delete data. But I agree with the advice to back up the NAS first.
It might not fix the problems (my guess is that it won't). You likely will need a factory reset (which deletes everything).
- Jul 15, 2018Retired_Member
