keeprg8
Nov 19, 2016Aspirant
RNDU4000 - OS Reinstall, fix frontview and various other problems
model: RNDU4000, firmware 4.2.28 Hi All, I recently had an: "ERR: Could not find internal fla" I fixed it with the "USB Restore flash" guide and it appeared to be working normally ... ...
- Nov 24, 2016
Okay ... Tried what I beleive is everything, found the (afaik) original .deb files from "/var/cache/apt/archives/" and executed "apt-get -i *.deb" in that directory, manually "apt-get install"'ed the oldest versions, took a chance, rebooted the nas - and presto - now everything works ...
So ... note to self .. dont "apt-get upgrade" blindlessly :o)
If you for some reason deleted the files from "/var/cache/apt/archives/" then "Factory Default" might be the only solution ...
Nov 21, 2016Guru - Experienced User
keeprg8 wrote:
Does a series of commands from commandline exist that can backup the frontview settings?
Probably there are, but unfortunately I don't know them.
keeprg8
Nov 21, 2016Aspirant
Hi,
Thank you for your time, I will investigate further and post here if/when I find a solution
Regards
- keeprg8Nov 24, 2016Aspirant
- Jul 15, 2018Retired_Member
