pcpro1
Oct 12, 2017Aspirant
RNDU4000 Portforward settings in router
When I access my RNDU4000 over Internet I only get IP/shares to work If I try IP/admin, I get an error page I have portforward port 80, do I have to do something else ?
Sandshark
Oct 13, 2017Sensei - Experienced User
You need to forward the https port and use https, not http. You could enable HTTP admin access, but that's a really bad idea when you've forwarded port 80. I recommend you not forward port 80 at all and use https for share access, too. The standard https port is 443, but you can use an alternate one, too, which may cut down on anyone snooping out your NAS. Where you specify the alternate port the NAS will use depends on whether you are still on RAIDar4.2.x or have moved to 6.x on your Ultra. The only real eason you'd need to use the NAS alternate port is if your router does not allow you to specify different LAN and WAN ports for forwarding. Otherwise, just choose an alternate incoming port in the router. If you do use an alternate port, you have to add a colon and the port to the end of the URL.
- pcpro1Oct 19, 2017Aspirant
Its RAIDar4.2.x on this one
I just tried what works or not
And even after I added portforwarding for https port 443 it wont work to access /admin remotely.
Should I choose TCP or TCP/UDP ?
Still its only /shares that I can acess
cifs, ftp, http/s is shared in settings
All users are in the group "users"
I then disable http on port 80 forwarding so then its not browsable at allUsing https on 443 is not working
Not even if I write IP:443
Tried another port also 5656, not workingLocally if I share folders using cifs, all folders are visible and accessable with admin passw
That might be ok, but how do I restrict different other users to access some folders ?
I shared everything, cifs, ftp, http/s to testFTP works great, can access all folders
But not via https
What about qouta ?Does 0 mean infinite space or zero space ?
Why set a qouta anyway ?
You can set qouta on both groups and users, makes me confused...
- StephenBOct 19, 2017Guru - Experienced User
Still its only /shares that I can acessHTTPS uses TCP, so that is enough. Then use https://wan-ip-address/admin from an external place (more likely using a ddns name than the wan ip address).
Does http://canyouseeme.org/ show the port as open? Sometimes ISPs block ports. Your router might also reserve 443 for it's own remote management. So maybe also configure a different destination port (say 50000) to also forward to the NAS 443 destination port, and try https://wan-ip-address:50000/admin
Great!
50000 to 443 works
But I get browser warnings about unsafe site and https is crossed over.
About users and groups
I created myself as a user in same group as all others, Group named users.
When I login using https://wan-ip-address:50000/shares I see same as the admin sees ?
Isnt it possible to configure so some users cant see/access certain folders ?
And where are the home folders, I can not see them.Whats the point making a group when the only thing I can set is quota ?
Is 0 the same as unlimited ?
