pcpro1
Oct 12, 2017Aspirant
RNDU4000 Portforward settings in router
When I access my RNDU4000 over Internet I only get IP/shares to work If I try IP/admin, I get an error page I have portforward port 80, do I have to do something else ?
Oct 19, 2017Guru - Experienced User
pcpro1 wrote:
And even after I added portforwarding for https port 443 it wont work to access /admin remotely.
Should I choose TCP or TCP/UDP ?
Still its only /shares that I can acess
HTTPS uses TCP, so that is enough. Then use https://wan-ip-address/admin from an external place (more likely using a ddns name than the wan ip address).
Does http://canyouseeme.org/ show the port as open? Sometimes ISPs block ports. Your router might also reserve 443 for it's own remote management. So maybe also configure a different destination port (say 50000) to also forward to the NAS 443 destination port, and try https://wan-ip-address:50000/admin
pcpro1
Oct 19, 2017Aspirant
Great!
50000 to 443 works
But I get browser warnings about unsafe site and https is crossed over.
About users and groups
I created myself as a user in same group as all others, Group named users.
When I login using https://wan-ip-address:50000/shares I see same as the admin sees ?
Isnt it possible to configure so some users cant see/access certain folders ?
And where are the home folders, I can not see them.
Whats the point making a group when the only thing I can set is quota ?
Is 0 the same as unlimited ?
