pcpro1
Oct 12, 2017Aspirant
RNDU4000 Portforward settings in router
When I access my RNDU4000 over Internet I only get IP/shares to work If I try IP/admin, I get an error page I have portforward port 80, do I have to do something else ?
Oct 20, 2017Guru - Experienced User
pcpro1 wrote:
Great!
50000 to 443 works
But I get browser warnings about unsafe site and https is crossed over.
That is expected - that happens because the NAS uses a self-signed certificate, so authentication isn't possible. It is possible to add that certificate to your PC's root store (details depend on the specific OS). You can also save a security exception in the Mozilla browser.
Personally I just click through it.
pcpro1 wrote:
Is 0 the same as unlimited ?
Yes. Do you think you need to limit the amount of storage your users can take?
pcpro1 wrote:
And where are the home folders, I can not see them.
These folders are intended to be private (personal folders for each user). If you log in as a specific user, you should see only the home share for that user. I believe you need to access the NAS using SMB or CIFS with that user's credentials first (that triggers the creation of the folder).
As Admin, you can see them from the web ui. You can also access the full data volume with SMB using admin credentials (\\nas-ip-address\data in windows file explorer). You will see a home folder there, and if you navigate into it you can see all the user home folders.
pcpro1 wrote:
Whats the point making a group when the only thing I can set is quota ?
If you have more than one user that have the same share access rights, then it is simpler to put those users into a group, and manage the permissions for the group as a whole (instead of for each user).
pcpro1 wrote:
Isnt it possible to configure so some users cant see/access certain folders ?
Generally you can't prevent selecting users from seeing a share (other than the home folders). You can prevent them from accessing the contents (seeing what's in the folder).
pcpro1
Oct 20, 2017Aspirant
Ok, I got a problem with this.
Se this post
https://community.netgear.com/t5/Using-your-ReadyNAS/RNDU4000-Adding-and-editing-a-share/td-p/1400168
