jetheroheller
Mar 20, 2016Tutor
RNDU600 stuck at "Booting... checking root FS"
Running OS6.4.2 on RNDU600 on 6 2TB drives set up as RAID-5. When either hard or soft shutdown, upon powering up the LCD gets to "Booting...checking root FS" and stays there. It's been there for 16 ...
- Mar 20, 2016
Update:
in private message, mgdm got me to send him a image of my corrupted file system for analysis through tech mode, then was able to reset the os remotely.
System booted without issue, but needs to be reconfigured.
The data volumes and all of the addons were present.
I was able to restore my config from a recent backup and restart the system, getting my configuration back.
Some add-ons worked (plex) while others did not (transmission, sickbeard).
But at least the NAS is back up and I can start to fix things.
Thanks so much mdgm-ntgr.
jetheroheller
Mar 20, 2016Tutor
attempted the boot menu 'os reinstall', but still locked up at 'checking boot FS'. Not sure if the OS reinstall was successful (i.e happened before the 'check boot FS' failure) or didn't happen (i.e. check boot FS failure prevented reinstall of OS)
- RAIDAR from my PC, nor ReadyNAS cloud, can detect the unit while in the booting state.
Scouring the forum for similar posts...
I read through this troubleshooting, and nothing here seems to match. However, i am currently doing the built in disk test from the boot menu to see if I can detect failed disks. I normally get email SMART alerts before a failure, and I've tested the only one that has ever given a hint, so I'm not expecting a failed disk, but one never knows.
http://kb.netgear.com/app/answers/detail/a_id/29772
- YAY, RAIDAR CAN detect the array during DISK TEST. First time I've seen the NAS communicate in a few days.
Depending on the outcome of the disk test, is it possible it's my flashed firmware? Should I attempt USB recovery?
http://kb.netgear.com/app/answers/detail/a_id/29952/~/readynas-os-6%3A-usb-recovery-tool
Based on this post:
- BrianL2Mar 20, 2016NETGEAR Employee Retired
Hi jetheroheller,
If you don't have a backup of your files, boot the device in Volume Read Only mode and see if they'll be available. If this works, start backing them up then we'll work on your main issue afterwards.
Kind regards,
BrianL
NETGEAR Community Team- jetherohellerMar 20, 2016Tutor
It's ReadyNAS Ultra 6 + (RNDU600) running R4toR6_6.4.2.bin (OS 6.4.2).
The disk that was hinting at failing looked fine w.r.t. SMART and tested fine with WD Diagnostics, but had 9 pending sector counts. That was the only hint I caught, and only showed up as a caution in CrystalDiskInfo, showed up as test passed WD Diagnostics. There were no emails from the NAS or other errors.
I haven't tried booting without that drive because I wanted to exhaust the diagnostics before triggering something that might result in a resync event, if possible.
So what's next? I'll try to figure out how to trigger volume read only mode, but otherwise, what do we do?
- mdgm-ntgrMar 20, 2016NETGEAR Employee Retired
I have just sent you a PM with the details of what we can try if volume read-only mode (on legacy NAS running OS6 this is triggered if you select the skip volume check boot menu option)
How do I boot to Volume Read Only mode? I checked this KB, and as I found with my unit, there doesn't seem to be such a mode.
What errors was the disk that was hinting at possibly failing giving? It sounds like there may be a problem with the root filesystem on the disks in which case it might not be possible to boot into volume read-only mode. If you can't boot into volume read-only mode we can discuss what the next appropriate step is.
No, this problem doesn't suggest that there is anything wrong with the firmware on the internal flash so doing USB Boot Recovery would be a waste of time and if anything may introduce a new problem.
Also as you have an RAIDiator-x86 4.2.x unit if you were going to do USB Boot Recovery you would use the USB Recovery tool for RAIDiator 4.2.x (but you could use OS6 firmware renaming it to RAIDiator-x86-something).
