Pavel-D
Jul 27, 2017Aspirant
RNDX4000 autoexpand volume failed
Hello! Before my rndx had 4x2tb disks (10 raid). Than i change to 4x4tb. But autoexpand of volume did't happen. Yes of course i reboot nas after new 4x4tb rebuilnding several times. I found on this...
Jul 27, 2017Guru - Experienced User
I am a bit confused, since AFAIK the NVX doesn't support RAID-10.
Can you confirm
- the firmware you are running
- what RAID mode you are using
Pavel-D
Thx for reply!
Screenshot of main page http://joxi.ru/MAjpDP6S4GLlVm?d=1 (firmware version and raid type)
