btaroli
Apr 07, 2014Prodigy
ROS 6, OpenSSL, and package updates?
No sooner do I read this evening that Fedora and others a re quickly working to get OpenSSL 1.0.1e out to fix the latest TLS bug that I log into my 516 to see what version it's running. Oh my, 1.0.1e....
btaroli
Apr 09, 2014Prodigy
alanwsg wrote: -- did they REALLY update the package but not change the version number?
The remediation options (see notes at http://heartbleed.com/ ... Reading IS fun!) were to upgrade to 1.0.1g or rebuild on existing version with an option to disable the problematic TLS heartbeat function. This is the latter. It also makes it a bit confusing since you'll see new revisions of what appears to be the same OpenSSL package. I hesitate to call it a patch when it's just a new alternate build, but it's certainly fixed. ;)
But this is why you need to verify the build date, since just looking at the package version may not be enough.
If you're very paranoid there is a test tool at http://filippo.io/Heartbleed/
And if you are (wisely) planning to change passwords, don't do it until you (or any affected website) have applied a fixed build AND have applied new site keys -- since /private/ keys may have been leaked and there's no way to be sure they weren't.
