chriscpr
May 07, 2019Initiate
RR3312 6.10 hotfix 2 cannot be accessed by hostname
Upgrade to 6.10 hotfix 2 happened last night and as of this morning when users got in, all of their mapped drives, which are mapped by group policy, are inaccessible. Giving an error that the connect...
chriscpr
Alternatively, is there a way to roll back to 6.9.5 hotfix 1, the last known good firmware image?
- StephenBMay 07, 2019Guru - Experienced User
Netgear says not to, so there would be some risk.
- SandsharkMay 07, 2019Sensei
You are experiencing what is an all-too-common problem. And chances are it was the re-boot of the NAS that accompanied the OS update, not the new OS version itself, that did it.
I also suffer from the problem (and have since well before 6.10.0, to which I have not even updated) and have yet to find a real solution. There are two work-arounds: add the NAS name to the computers' HOSTS files or change the drive mapping to use the IP address instead of the name. Both of those, of course, require a non-changing NAS IP address, which it is best to do via IP reservation in your router or other DHCP device than fixed IP in the NAS.
- Mar 14, 2019Retired_Member
