tbspray7
Jul 20, 2020Aspirant
RR3312 Copying Errors
Hello, We have ReadyNAS 3312 (RR 3312 w/ 12 bay, Firmware: 6.10.3) that has been throwing volume alert message reading: "The volume data encountered an error and was made read-only. It is recomme...
Sandshark
Jul 22, 2020Sensei
Well, then I can't point to anything that I think could have caused it, though i suppose there could still be an issue with the NAS hardware. I can say that it's atypical and I don't think you should be concerned you'll be encountering it periodically. I've used a variety of ReadyNAS over the years, including my current use of legacy rack-mount systems converted to OS6, and I have only seen this once. And that was mostly my fault -- the eSATA cable between an RN516 and EDA500 was loose, causing a lot of data issues. (I say mostly my fault because the choice of connector for eSATA is just a really bad engineering decision -- not Netgear's, mind you, but by whoever designed the interface standard. )
Occurrences of similar issues reported in this forum typically have an identifiable cause (usually a failing drive with at least ATA errors or lack of proper UPS protection).
Since I knew what caused it and that it was corrected, I thought I could save the volume. That's where I got the experience to say don't even try. No matter what I did, the volume was read-only again within minutes. Since my corrupt volume was on the EDA, I could just destroy and re-create it and not touch the primary volume. I feel your pain in the data restoration -- the EDA500 is extremely slow due to the eSATA interface, and I had 5x6TB in it in RAID5. But it was mostly archival data, so that probably made it a little less painful than yours will be if you are without current working data for any period of time.
The volume rebuild process will also be a good gauge of whether you do have a hardware issue, so check the logs after that completes.
tbspray7
Jul 23, 2020Aspirant
We were doubting it was hardware, but still a small possibilty. Thank you for advice and all of the help. We will try the rebuild and post back here if we get something figured out. Oddly enough, I have a friend has seen this error thrown on their other two ReadyNAS servers, but has never been able figure out why it happened on their end, only that its periodically occured.
