robosmith
Aug 29, 2020Aspirant
Readynas Duo network error terminates file copy
I have been trying to copy a 109GB file to my Readynas Duo for several days now.
It gets from 1/3 to 2/3 of the way through the copy and then I get a network error messege with retry button.
Clicking retry, just starts the copy over, asking if I want to overwrite the file on the disk.
I can still access the drive with Raidar
I have disabled disk spindown and sleep on the PC which is the source of the file copy.
Checking the log files, I found the following in smbd.log:
[2020/08/29 12:13:06.422460, 0] lib/util_sock.c:680(write_data)
[2020/08/29 12:13:06.461397, 0] lib/util_sock.c:1441(get_peer_addr_internal)
getpeername failed. Error was Transport endpoint is not connected
write_data: write failure in writing to client 0.0.0.0. Error Transport endpoint is not connected
[2020/08/29 12:13:06.462019, 0] smbd/process.c:79(srv_send_smb)
Error writing 39 bytes to client. -1. (Transport endpoint is not connected)
Of course a file this large takes hours to copy, but I have copied large files to it before (up to 3x larger) and not had this (repeated) problem. While the disks are 85% full, Raidar says there is over 5GB free space.
Does anyone here know why this is happening and/or a fix?
What firmware are you running?
Did you mean 5 TB of disk space?
What are you copying from? Is it using ethernet or wifi?
Have you looked for disk-related errors in the log zip?
- robosmithAspirant
It says Raidiator 4.1.16
I just checked and there is an update available so I started the update.
StephenB wrote:Did you mean 5 TB of disk space?
No, I meant 500GB of disk space.
StephenB wrote:What are you copying from? Is it using ethernet or wifi?
From PC over Wifi.
StephenB wrote:Have you looked for disk-related errors in the log zip?
I stopping looking through the log files when I found the network error which was specified in the error dialog.
Where should I look for disk error?
- robosmithAspirant
StephenB wrote:What firmware are you running?
robosmith wrote:I have been trying to copy a 109GB file to my Readynas Duo for several days now.
After upgrading to the latest version: RAIDiator 4.1.16 1.00a043
I tried one more time to copy the file and this time it copied the whole thing.
Thanks for the suggestion.
Great.
Ideally you'd keep around 10% free space on your NAS (which I think is what you are at now).
The max disk size it can handle is 2 TB.
