robosmith
Aug 29, 2020Aspirant
Readynas Duo network error terminates file copy
I have been trying to copy a 109GB file to my Readynas Duo for several days now. It gets from 1/3 to 2/3 of the way through the copy and then I get a network error messege with retry button. Clicki...
- Aug 29, 2020
What firmware are you running?
While the disks are 85% full, Raidar says there is over 5GB free space.
Did you mean 5 TB of disk space?
What are you copying from? Is it using ethernet or wifi?
Have you looked for disk-related errors in the log zip?
robosmith
Aug 30, 2020Aspirant
StephenB wrote:What firmware are you running?
robosmith wrote:I have been trying to copy a 109GB file to my Readynas Duo for several days now.
After upgrading to the latest version: RAIDiator 4.1.16 1.00a043
I tried one more time to copy the file and this time it copied the whole thing.
Thanks for the suggestion.
Aug 30, 2020Guru - Experienced User
Great.
Ideally you'd keep around 10% free space on your NAS (which I think is what you are at now).
The max disk size it can handle is 2 TB.
