SLK-Purdue
Dec 22, 2020Luminary
RSync - am i missing something obvious? (RN312/RN102 with 6.10.4)
I feel like I am missing something obvious but I don't see it. I have used Rsync on Unix and I think I know the concepts. :-) Source is RN312 running 6.10.4. Target is RN102 also running 6.10....
SLK-Purdue
A bit more information - if I set up the backup Rsync from a specific source folder to a specific destination folder, that works OK. It would seem a clue might be that both reports are trying to backup from /data.
Scott
rn_enthusiast wrote:Seems similar to this post
Maybe we have a trend on the 6.10.4 firmware Marc_V and JohnCM_S ?
SLK-Purdue
On second thought, is this a recursion problem? If the "r" option is missing or not working, this could explain what I am seeing. I will test this theory when I can but wanted to put it out for others to consider.
SLK-Purdue wrote:A bit more information - if I set up the backup Rsync from a specific source folder to a specific destination folder, that works OK. It would seem a clue might be that both reports are trying to backup from /data.
Scott
- StephenBDec 23, 2020Guru - Experienced User
Recursion is working on my systems - backing up individual shares using "pull" backups (meaning that the source is remote).
- Marc_VDec 23, 2020NETGEAR Employee Retired
HI All,
Happy Holidays! We would like to request for the full logs of your NAS if possible, kindly send it via PM.
Many thanks!
- SLK-PurdueDec 23, 2020Luminary
Link sent to source and destination logs on Dropbox. These logs include the test of sending just one folder that worked. Look for the Rsync of /data.
Thanks for the help and Happy Holidays!!
Scott
Marc_V wrote:HI All,
Many thanks!
- SLK-PurdueDec 24, 2020Luminary
Update - after more testing, it is NOT related to recursion (rysnc "r" parameter). Doing Rsync for a folder with folders inside folders works fine and creates both the directory structure and content. That point the problem back to an Rsync for the volume /data on 6.10.4. I don;t have an easy way right not to go back to 6.10.3 or earlier for testing.
Scott
SLK-Purdue wrote:Link sent to source and destination logs on Dropbox. These logs include the test of sending just one folder that worked. Look for the Rsync of /data.
Scott
Many thanks!
- SLK-PurdueJan 01, 2021Luminary
Did the logs should anything interesting?
Scott
