SLK-Purdue
Dec 22, 2020Luminary
RSync - am i missing something obvious? (RN312/RN102 with 6.10.4)
I feel like I am missing something obvious but I don't see it. I have used Rsync on Unix and I think I know the concepts. :-) Source is RN312 running 6.10.4. Target is RN102 also running 6.10....
Marc_V
Dec 23, 2020NETGEAR Employee Retired
HI All,
Happy Holidays! We would like to request for the full logs of your NAS if possible, kindly send it via PM.
Many thanks!
SLK-Purdue
Dec 23, 2020Luminary
Link sent to source and destination logs on Dropbox. These logs include the test of sending just one folder that worked. Look for the Rsync of /data.
Thanks for the help and Happy Holidays!!
Scott
Marc_V wrote:HI All,
Many thanks!
- SLK-PurdueDec 24, 2020Luminary
Update - after more testing, it is NOT related to recursion (rysnc "r" parameter). Doing Rsync for a folder with folders inside folders works fine and creates both the directory structure and content. That point the problem back to an Rsync for the volume /data on 6.10.4. I don;t have an easy way right not to go back to 6.10.3 or earlier for testing.
Scott
SLK-Purdue wrote:Link sent to source and destination logs on Dropbox. These logs include the test of sending just one folder that worked. Look for the Rsync of /data.
Scott
Many thanks!
- rn_enthusiastDec 24, 2020Virtuoso
Thanks for testing SLK-Purdue
I have an rsync job that backs up my volume (/data) to another NAS and that works perfectly fine on 6.10.3. I will stay on that firmware for now until Netgear has tested and reverted back to us.
Cheers
- SpaceTintinJan 03, 2021Star
I am having the exact same symptom on a deployment with a 3312 backing up to a 314. When running on 6.10.3 the Rsync via SSH functions correctly to backup the entire volume (/data), but if I upgrade to 6.10.4 the back-up says it runs successfully in a few seconds (should take it a few hours nightly) and dones't update any of the files, but will only update folder structure changes. For now I reverted back to 6.10.3 for now and rsync works again. Hoping for a fix on this. Different problem, but still not fixed, the backup setup still messes up the destination file address with an extra "\" when using the gui and I have to edit it out of the backup scripts via ssh before the rsync via SSH even works to begin with.
