SLK-Purdue
Dec 22, 2020Luminary
RSync - am i missing something obvious? (RN312/RN102 with 6.10.4)
I feel like I am missing something obvious but I don't see it. I have used Rsync on Unix and I think I know the concepts. :-) Source is RN312 running 6.10.4. Target is RN102 also running 6.10....
SpaceTintin
Jan 03, 2021Star
I am having the exact same symptom on a deployment with a 3312 backing up to a 314. When running on 6.10.3 the Rsync via SSH functions correctly to backup the entire volume (/data), but if I upgrade to 6.10.4 the back-up says it runs successfully in a few seconds (should take it a few hours nightly) and dones't update any of the files, but will only update folder structure changes. For now I reverted back to 6.10.3 for now and rsync works again. Hoping for a fix on this. Different problem, but still not fixed, the backup setup still messes up the destination file address with an extra "\" when using the gui and I have to edit it out of the backup scripts via ssh before the rsync via SSH even works to begin with.
Jan 03, 2021Guru - Experienced User
You could also temporarily run the rsync backup job(s) on the RN314 (which will work with 6.10.4).
