rekoil
Sep 14, 2014Aspirant
Rsync backup --ignore-times option
Hi, I'm upgrading from a Duo to a 312, and in the process of copying all of my data - about 700GB - from the Duo over to the 312. I'm using the rsync backup method, as I'm keeping the Duo in use un...
Sep 14, 2014Guru - Experienced User
--ignore-times is not used on the incremental backups. The fastest approach is to use NFS, then edit the backup to use rsync and rerun it.
I'm not sure why you have a second rsync process running.
