daKlone
Aug 01, 2016Aspirant
RSync Backup Failed...Why?
I'm having trouble getting a backup job to run to completion. I've run it twice so far and it has failed both times, sadly I didn't record the error message for the first one, but this time I got thi...
- Aug 08, 2016
Well, the news is finally good! :smileyhappy:
I ran a scrub on the main NAS (which took ages!) and waited for the backup jobs to run on Sunday night. They all ran (incrementally) to completion and I double-checked the folders using FreeFileSync and they are indeed identical.
I call that a win.
Thanks everyone for thier help, it's much appreciated :smileyhappy:
Aug 02, 2016Guru - Experienced User
daKlone wrote:
Backup Destination: [Videos]//
Normally would be just one / here, not two. That is, share: Videos in the name field with path blank.
But the backup ran for 29 hours before failing, correct? So it is unlikely to be a syntax error, that would fail right away.
Did it run about the same amount of time on the first backup run? I'm wondering if it failed on the same file.
