daKlone
Aug 01, 2016Aspirant
RSync Backup Failed...Why?
I'm having trouble getting a backup job to run to completion. I've run it twice so far and it has failed both times, sadly I didn't record the error message for the first one, but this time I got thi...
- Aug 08, 2016
Well, the news is finally good! :smileyhappy:
I ran a scrub on the main NAS (which took ages!) and waited for the backup jobs to run on Sunday night. They all ran (incrementally) to completion and I double-checked the folders using FreeFileSync and they are indeed identical.
I call that a win.
Thanks everyone for thier help, it's much appreciated :smileyhappy:
Aug 02, 2016Guru - Experienced User
daKlone wrote:
Backup Destination: [Videos]//
Normally would be just one / here, not two. That is, share: Videos in the name field with path blank.
But the backup ran for 29 hours before failing, correct? So it is unlikely to be a syntax error, that would fail right away.
Did it run about the same amount of time on the first backup run? I'm wondering if it failed on the same file.
daKlone
Aug 02, 2016Aspirant
I tend to agree with StephenB - if there were a command syntax error then the backup wouldn't have run at all. I will double-check it though.
It did fail at about the same duration when I tried to run it the first time, so it is possible that the same file has "killed" it.
I had another thought along those lines. Is there a limit on the number of files that can be sync'd, or a limit on the size of an individual file?
That folder contains a lot of files, and one or two are really big (~40GB) so it is possible that either a) there are too many files to enumerate (unlikely), or b) it bombs out when it hits the first really big file.
What do you think?
- StephenBAug 02, 2016Guru - Experienced User
I did a factory reset on both my RN102 and RN202 (backup NAS) a couple months ago, and repopulated the data using RSYNC backup from my main NAS (pro-6). This was done share-by-share.
-biggest share is about 2 TB
-share with highest file count has 280K files
-several files bigger than 40 GB, the largest about 65 GB
So I'm thinking its not that likely to be a problem with size or enumeration.
How much free space would be on the destination NAS if the backup completed successfully?
One option is to focus on the source - checking the disk, or (if RAID) doing a scrub. Maybe resetting file permissions (though that should have given a different error).
Another approach is to organize the source into a few folders, and try using rsync to copy them them folder at a time. The idea there is to the problem down to the problem file.
You could even try a drag/drop from a PC, telling the PC to skip files that are already on the destination. That only makes sense if the bulk of the data was successfully transfered.
- daKloneAug 02, 2016Aspirant
There would be about 3.5TB free after the backup was complete (8TB total free on both devices, about 4.5TB used on the main NAS). My largest share is around 4TB, so twice the size of your largest.
Going forward I can't really re-organise the contents of the share as they are set up in a particular way for another application, but I suppose I could do it temporarily for testing purposes. I'll start with the file that killed it last time on it's own and see if that works.
I could use Free File Sync instead of RSync of course, but that's what I'd been doing my backups with upto now and the whole point of buying another NAS was to take the PC out of the loop, increase automation and reduce power requirements (by having the backup NAS sleep unless it was actively backing up).
It will be interesting to see if the subsequent backup jobs complete properly, as this one is only the first of about half-a-dozen (one per share) that were scheduled. The jobs themselves are running on the backup NAS (the RN104).
If you know what file killed it last time, then you can simply try copying that. I was thinking about re-organizing just to help you isolate it.
daKlone wrote:
...the whole point of buying another NAS was to take the PC out of the loop, increase automation and reduce power requirements (by having the backup NAS sleep unless it was actively backing up)...The jobs themselves are running on the backup NAS (the RN104).
Yes, and that should work. I also run the jobs on the backup NAS.
What is the main NAS? (it doesn't matter if it is netgear or not btw).
