Soldermonkey
Jan 31, 2021Aspirant
Rsync backup job reports false success
After taking on the 6.10.4 firmware update on both local and remote NAS boxes, my daily rsync-over-ssh backup job reports a false success. It returns immediately, but no files are transferred or upd...
Soldermonkey
Here's the e-mailed log:
Successfully completed backup job Rsync All to TLC-REMOTE-NAS1. -------- Backup Job Information -------- Backup Job Name: Rsync All to TLC-REMOTE-NAS1 Backup Job Type: Incremental Protocol: rsync+ssh Backup Source: [volume:data]/ Backup Destination: [remote:rsync+ssh]/<redacted>://data/Replications/TLC-NAS1_via_rsync Backup Start Time: Sun Jan 31 2021 12:05:10 AM Backup Finish Time: Sun Jan 31 2021 12:05:11 AM Backup Status: Success -------- Backup Job Log -------- sending incremental file list sent 486 bytes received 37 bytes 348.67 bytes/sec total size is 0 speedup is 0.00
- StephenBFeb 01, 2021Guru - Experienced User
This has been reported already. For now the best thing to do is drop back to 6.10.3.
- rn_enthusiastFeb 01, 2021Virtuoso
Would be nice with some kind of update from Netgear on this, though.
Agreed. It happens on every system, so there's no issue with them reproducing it.
- SoldermonkeyFeb 01, 2021Aspirant
Is it necessary to downgrade both the sending and receiving machines to 6.10.3 or can I, for example, only downgrade the sending machine?
- SandsharkFeb 01, 2021Sensei
You need to downgrade the one running the backup. So if it's a "push" job, the sender. If a "pull", then the receiver.
